sensor plug repair kit
Old Dec 7, 2010 | 10:57 PM
DiscoDad's Avatar
Default sensor plug repair kit
Anyone know of a ecu coolant sensor plug repair kit?
Old Dec 8, 2010 | 10:11 AM
Rebuild it by hand or go to a junk yard cause there is no such kit available.
Old Dec 8, 2010 | 07:17 PM
What exactly happened?
Old Dec 8, 2010 | 07:43 PM
DiscoDad's Avatar
Default What happened
Upper radiator hose blew and broke the plastic plug that snaps on the ecu sensor
Old Dec 8, 2010 | 07:46 PM
Got it.
That sucks.
As long as you can get a good connection with the spade clip and can make sure it wont fall off you dont actually need the plug.
So you might beable to Jerry Rig something.
Old Dec 8, 2010 | 09:00 PM
Danny Lee 97 Disco's Avatar
I was an Aviation Electrician and a Missile Manufacturing engineer. What you can do after you solder if possible or just crimp on spade connections, you can use what is called a "Potting Compound" to make your own insulating plug.
It is basically a two-part rubber -like material. You could make a small mold of some tape or something and pot it, or you could probably suffice with a good RTV type material. Just make sure the connections are well covered.
Old Dec 9, 2010 | 07:25 AM
DiscoDad's Avatar
Default Found repair kits!
This may help with future repairs. Connectorsfast.com has a repair kit for land rovers part ev1 can be gotten with plug only or with a
6 inch pigtail for quick repairs. Very reasonable too!!!
Old Dec 9, 2010 | 08:39 AM
XCELLER8's Avatar
thanks for digging up that site !!!!!!
I was ready to offer you a used one off of an old wiring harness I have , but at those prices you might better have a new one !
Old Dec 9, 2010 | 07:45 PM
Just added that to the tech section.
Perfect for those who might need a connector in the future.
KlamathMatt
Apr 17, 2020 05:27 AM
univu2
Jul 28, 2012 08:03 PM
primey
Oct 26, 2011 07:24 PM
Disco Alan
Apr 21, 2009 06:22 PM
