Seriously, why me. Now running hotter.
Old Jun 14, 2016 | 05:34 PM
FLA Rover's Avatar
Originally Posted by stillruns
What is the difficulty level in installing a 180 degree thermostat?
Some where around -3
Old Jun 14, 2016 | 05:35 PM
FLA Rover's Avatar
Originally Posted by ihscouts
Besides air are you sure you routed the serp belt correct?
I know it never hurts to ask but yes, routed correctly...
Old Jun 14, 2016 | 05:37 PM
FLA Rover's Avatar
Originally Posted by Gimebakmybulits
Depends on whether or not you shear one of the bolts off like I did.....
You mean like this!
Click image for larger version
Old Jun 16, 2016 | 07:17 PM
Mark G's Avatar
I third the Serpentine belt routing. How many people have come here only to find they routed it wrong and it slips at hwy speeds? Quadruple check with the 'correct' belt routing diagram (it's possible to put on two ways) ....also if the t-stat is in backwards.. fan backwards??
Lower red hose sucking in??
Start with the simple things first.
Old Jun 16, 2016 | 08:01 PM
stillruns's Avatar
I take it this isn't something I can do without some advanced tools.
Old Jun 16, 2016 | 09:29 PM
ihscouts's Avatar
In most cases that's not true. Simple hand tools do the job. It's when a bolt snaps or having a hard time removing the fan clutch that you might need one for that purpose. I haven't had issue with two pumps, clutches and thermostats but I'm lucky like that...... most of the time.
tdmadlem
Feb 15, 2015 03:26 PM
Moses7
Apr 17, 2013 07:00 AM
mossmanxjt
Nov 11, 2012 06:38 AM
moomoo
Aug 7, 2011 10:00 PM
rcpeddie
Dec 18, 2008 04:31 PM
