Serpentine Belt Tension
Old Nov 25, 2011 | 05:18 PM
pedro_malo's Avatar
Default Serpentine Belt Tension
So on my 98' Disco I my serpentine belt simply fell off. Nothing appears wrong with it but a little scary having the truck essentially shutdown at 80miles an hour. 2 questions:
What could cause the belt to fall off ? - no breaks or cracks.
I"ve ordered a new belt and loosened the pully to install but cannot get the pulley to re-seat. What's the trick? There is too much tension. The new belt appears to be same size as old.
Thanks.
Pedro
Old Nov 25, 2011 | 05:29 PM
Danny Lee 97 Disco's Avatar
Maybe the tensioner went bad?
Old Nov 25, 2011 | 07:24 PM
reboot's Avatar
do all your pulleys turn easily? A/C . Alternator, Tension Pulley etc.?
If you loosened the center bolt on the tension pulley that's not correct. You put a wrench on the nut/bolt on the pulley itself an d pull it toward the drivers side to get the belt on. Make sure the belt is on right. Discover Defender Maintenance Tips, Accessories, Parts & More at Roverparts.com
Old Nov 25, 2011 | 10:10 PM
Your belt did not fall off. It most likely was thrown off by one of the rotating things locking up, unless route was incorrect or tensioner was mis-adjusted.
Problem is, to duplicate this you may have to run engine to warm up the other things that turn. If turning them by hand when cold does not show up anything, you could put belt back on, and listen to each thing that turns (other than crankshaft pulley) with a stick pressed against your ear. Let engine run for a few minutes and re-check. Will probably hear a different sound from the bad guy. Also, watch the fan pulley for wobble, it does that if water pump bearing is failing. See attached photo.
Attached Thumbnails Serpentine Belt Tension-pulley-bolt.jpg   Serpentine Belt Tension-p1030593.jpg   Serpentine Belt Tension-p1030596.jpg
Old Nov 26, 2011 | 07:00 AM
pedro_malo's Avatar
Default serp-
Thanks guys- will investigate and post findings. That illustration in RAVE is useless. Its unclear which bolt to lossen.
Old Nov 26, 2011 | 07:14 AM
see attachd page, says clockwise to release.
File Type: pdf
Old Nov 26, 2011 | 07:52 AM
DiscoJag's Avatar
It is difficult to get the belt on and easy to route it incorrectly. I had to pull on the tensioner bolt (clockwise) with a fairly long wrench while my son pushed the belt over the lip of the alternator pulley. You're pulling the tensioner using the bolt, nothing is taken off. In fact, you would be tightening the bolt, but you are pulling against the spring.
Old Nov 26, 2011 | 08:06 AM
antichrist's Avatar
Old Nov 26, 2011 | 08:25 AM
If you have no tension when moving the tensioner arm then it has failed.
Old Nov 26, 2011 | 08:57 AM
pedro_malo's Avatar
Default serp.
Thanks for the illustrations. Looks like the tensioner is blown. Bleeding bearings. Ordered a new one from Advanced, which is having a good holiday sale online.
