shock tower retaining ring to RBC100111?
I bolted mine up yesterday. They worked fine, except one bolt (out of 8) broke free on the ring and turns in the rubber (this was even before the nut was fully seated much less tightened -- that's Land Rover quality for you. I imagine a spot weld on the ring failed but I can't see since it's encased in rubber. Still, I can feel the head turning around inside there so I know it's not sheared on the shaft. So they followed one lame design with a slightly better lame design. I expect that once I have the spring seated against the isolator it will put enough pressure on the loose bolt that I can torque the nut. A better design would have been to mold holes around the bolts so that standard headhead fasteners could be gripped with a socket. Even better, machine the spring seat out of aluminum and add the rubber piece if you want.
joyntanovich
01-27-2015 10:28 PM
