shock tower retaining ring to RBC100111?
Old Jul 15, 2011 | 10:30 AM
nevada ben's Avatar
Default shock tower retaining ring to RBC100111?
Can I replace this:
with this?
because I sheared the studs on the former on my way to 24 Nm torque. It held 17 Nm but sheared around 21. I suspect the part is moonglow to begin with. I'm hoping RBC100111 is better. Any reason it wouldn't fit a D1?
Old Jul 15, 2011 | 11:04 AM
jafir's Avatar
The original part on D1 and RRC are know for rusting away. I don't see why a new replacement wouldn't work fine. I have no idea about the D2 part.
Old Jul 15, 2011 | 11:54 AM
zackgnzls's Avatar
7th Gear
Old Jul 15, 2011 | 03:13 PM
XCELLER8's Avatar
YES, I did on mine.
Old Jul 15, 2011 | 03:14 PM
XCELLER8's Avatar
I should have added....you'll get a 10mm lift !!!!!lol
Old Jul 15, 2011 | 09:01 PM
Danny Lee 97 Disco's Avatar
Yeah, I bought a similar beefed up one when I redid my shocks and springs.
Old Jul 15, 2011 | 10:34 PM
Banzai Jimmy's Avatar
X3. Put them on my D1. Turns out the cone portion does its job when I get flexed out. With the original ring in there, the spring would not re-seat itself.
Old Jul 17, 2011 | 09:38 AM
nevada ben's Avatar
I bolted mine up yesterday. They worked fine, except one bolt (out of 8) broke free on the ring and turns in the rubber (this was even before the nut was fully seated much less tightened -- that's Land Rover quality for you. I imagine a spot weld on the ring failed but I can't see since it's encased in rubber. Still, I can feel the head turning around inside there so I know it's not sheared on the shaft. So they followed one lame design with a slightly better lame design. I expect that once I have the spring seated against the isolator it will put enough pressure on the loose bolt that I can torque the nut. A better design would have been to mold holes around the bolts so that standard headhead fasteners could be gripped with a socket. Even better, machine the spring seat out of aluminum and add the rubber piece if you want.
fishEH
Jun 7, 2015 06:42 PM
RezzaHD
Mar 5, 2013 09:50 PM
thehun
Jun 2, 2011 08:40 PM
jmt
Oct 23, 2008 01:52 AM
