Shopping For a Fuel Pump
Old Feb 21, 2015 | 11:08 PM
Travelor's Avatar
Default Shopping For a Fuel Pump
Hey All,
Not meaning to beat a dead horse - so to speak... But I'm shopping for a new fuel pump and I'm seeking some input.
I've read through a ton of posts, some recommending the purchase of the pump alone, some recommending the purchase of the complete Plug/n/Play unit. I am leaning to towards the complete unit. I'd rather not run into problems.
My disco is the non-advanced evap system, so I hope the list below contains the correct parts.
Please let me know your thoughts on the following parts.
Recommend replacing any rubber components?
Thanks in advance for your help and input.
Trav..
Let me know if you do or don't recommend the parts and/or the distributor.
PartsGeek
http://www.partsgeek.com/catalog/199.../fuel_delivery
ABL
Fuel Pump For Discovery And Range Rover Classic - Same As ESR3926
RoversNorth
FUEL PUMP/SENDING UNIT RANGE ROVER & DIS, PLF132, ESR3926 - Rovers North - Classic Land Rover Parts
APW
Replacement REPL314503 Fuel Pump | Auto Parts Warehouse
CPW
Land Rover Range Rover Fuel Pump Assembly from CarPartsWarehouse
Thanks Again For Your Input...
/fuel_pump.html
Old Feb 22, 2015 | 09:04 AM
TOM R's Avatar
With the non ael probly just buy the assembly since its cheap, the ones where guys say buy a pump is the Abel like mine cause pumps cheap assemblys some stupid price like 500
Everyone probly sells the same brand so I guess go with the best price
Old Feb 22, 2015 | 12:16 PM
fishEH's Avatar
I'd probably go with the ProLine from RoversNorth. Good price and you'll get good customer service from someone with Rover experience.
Plan on replacing the sealing ring, and possibly the retaining ring if you destroy it on removal.
Old Feb 22, 2015 | 12:34 PM
jafir's Avatar
On my 1996 I bought that $99 unit from rovers north, but I didn't get the link lead. I didn't need it. I'm not sure why it says that it needs it. Maybe some do for some reason. I'd look at the old one and see if the connector looks the same. I did get new hardware, the olive and fitting.
Old Feb 22, 2015 | 12:37 PM
Travelor's Avatar
Hi Guys!!
Thanks for the input.
I do have another question. I noticed on the RN website that there is a wiring harness offered. Is this harness necessary?
Thanks,
Trav...
Old Feb 22, 2015 | 12:49 PM
jafir's Avatar
Originally Posted by Travelor
Hi Guys!! Thanks for the input. I do have another question. I noticed on the RN website that there is a wiring harness offered. Is this harness necessary? Thanks, Trav...
I don't know.
Old Feb 22, 2015 | 12:52 PM
Travelor's Avatar
jafir!!! You answered before I even asked the question.
I will check the connectors on my Rover.
Trav...
Old Feb 22, 2015 | 12:54 PM
jafir's Avatar
You'll probably need some new screws to hold the metal cover over the access hole in the load space. My D1 had absolutely no rust in the body, but those screws were so rusty I had to remove them with vice grips.
Old Feb 22, 2015 | 01:30 PM
Travelor's Avatar
No Doubt.. .
My D1 was raised here in Southern California no rust at all.. But those screws are toast..
Thanks again for the input..
Trav..
Old Feb 22, 2015 | 03:58 PM
fishEH's Avatar
Some SS screws from Lowe's do the trick.
The harness mentioned is probably the one from the pump to the drivers side rear wheel well area. As Lind as you have power to the pump you probably don't need the harness.
