So I bought at D2 rear door...
Old Feb 19, 2013 | 12:55 PM
pinkytoe69's Avatar
Default So I bought a D2 rear door...
I thought I had read that the D2 cargo door can drop right in a D1.
Well, 90% of it does, but the lock/latch are different sized, aligned differently, and mounted in a slightly different spot.
Any thoughts about what I could do with it (other than post it on CL and hope)?
I can swap out the wiper, motor, glass/seal, and speaker housing, but I dunno if that would be worth the trouble.
Old Feb 19, 2013 | 01:14 PM
EricTyrrell's Avatar
Switch the locks?
Old Feb 19, 2013 | 01:33 PM
pinkytoe69's Avatar
I would, but the lock systems are completely different and have different mounting points.
Seems like a huge PIA to swap.
Old Feb 19, 2013 | 02:07 PM
greenharoguy's Avatar
Make new mounting points?
Old Feb 19, 2013 | 02:48 PM
hilltoppersx's Avatar
you have two options. weld it in place. buy a d1 door.
Old Feb 19, 2013 | 03:22 PM
pinkytoe69's Avatar
Originally Posted by hilltoppersx
weld it in place.
Haha, I coulda gone to Dweb for that kinda advice!
Seriously though, thats pretty much what I expected...f'ed. At least it was only $50.
Were there any improvements in the glass to make that swap worthwhile?
Old Feb 19, 2013 | 03:38 PM
I'm sure if you slam it hard enough it'll work itself out
Old Feb 19, 2013 | 04:40 PM
binvanna's Avatar
Too bad LR didn't make LHD-specific rear doors for the Discovery. On a LHD car, the driver looks over their right shoulder for a nice view of the spare tire. I guess so they can see it's still there.
On the LR3, they actually swapped the direction the glass dips, but for some inexplicable reason the RHD models were then dipped on the wrong side, and all for no reason since the spare is now mounted underneath. I guess they were just trying to copy the Xterra.
The thing is, even if you rear-mount a spare with a carrier, the hinge still swings the door the wrong way so you either have the spare still on the wrong side (for LHD) or you have to make the carrier swing opposite the door.
Old Feb 19, 2013 | 07:10 PM
i totally forgot one more option. you can buy a d2 without a rear door and use the rear door you have to fill the gap
Old Feb 20, 2013 | 03:28 PM
Sam95disco's Avatar
Better yet, don't buy parts for a car you don't have.
