Spark Plugs and cruise, argh!
Old May 26, 2013 | 08:37 AM
jdblep's Avatar
Default Spark Plugs and cruise, argh!
So i swapped plugs this weekend, and it appears to be running rougher than before the swap. In addition, there is pronounced noise coming through my aftermarket stereo. I used Bosch Copper Plus (7907), but am thinking about changing them to something else. I pulled out Denso W16EXR-u11 plugs, that were gapped beyond recommendation (probably .040+). Any recommendation on choosing a new plug. Some posts are stating bosch platniums, and others are saying just use a cheap copper plug.
I also swapped out the cruise module for the DII one, (rewiring the new harness) but still no cruise. Is there an easy to test the vacuum pump (already replaced the vacuum lines), or other parts of the cruise system? I can hear the module click when i turn it on, and press the set/res buttons on the steering wheel.
Thanks!
1998 D1
Attached Thumbnails Spark Plugs and cruise, argh!-8539382801_503990b948_k.jpg
Old May 26, 2013 | 09:35 AM
Have you checked all your vacuum lines for the cruise control issue?
As for the plugs, seriously consider a set of E-3 spark plugs, no gapping required, lots of low end torque and a 5 year warranty.
Old May 26, 2013 | 09:01 PM
jdblep's Avatar
looks like it was the vacuum pump. it works, but doesnt have enough suction to move the throttle diaphragm. (All hoses tested OK). It looks like the D2 pump is the same but has 5 connectors instead of 3, i wonder if it would work?
Old Jun 4, 2013 | 12:37 PM
thearmlesswonder's Avatar
Question Follow up
Hello ! I have the same issue. replaced a vacuum lines and fuse. No curise .... The switch lights up of course ...
How did you test it ? no while moving I hope lol
Also did you swap back to a stock Disco I module and get it working ?
Thanks !!!
Old Jun 4, 2013 | 01:23 PM
jdblep's Avatar
i tested it by running power off my battery, but it didnt have enough suction to pull the diaphragm connected to the throttle. I ordered a used vacuum pump on ebay, which should be here today.
Old Jun 4, 2013 | 08:10 PM
Wink
Well that makes .... sense .... duh ... lol I sould have put more thought in to it.. Thanks !!
Let us know how it woks out !!
discodorothy
Sep 9, 2021 11:15 AM
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
Scotauto
Mar 22, 2013 09:14 PM
grussell
Jul 13, 2009 05:57 PM
