Speakers that have succesfully fit.
Any way to change the entire wiring for the sound system? The reason I ask is that none of my speakers work except one. All the speakers are good (Checked the impedance and they are all 4ohms which is normal). The wires are all jacked up. How did they hide the wires? Are they in the floor side guards, under the carpet, or what?
Your amp might be toast.
I would test each speaker with a known good source first, then use a known good speaker to test each output. If you are testing the speakers at the output of the deck, you may be going through the amp and reading the impedence there, not the speakers. I would still suggest testing where you can hear it. It isn't hard and you will know for sure. Then you can start running things down....
Speakers that fit!
I just bought some speakers from wal-mart for $24 a pair three-way sound that fit perfect in the front doors and rear post. I also, used them to replace the subs in the rear door. All are working fine with no modification to the wiring or body opening.
Good Luck!
Dan
96' Disco I
154,308
Good Luck!
Dan
96' Disco I
154,308
