Speakers that have succesfully fit.
Old Dec 21, 2010 | 05:29 AM
jdhuegel1's Avatar
Originally Posted by calebbo
Any way to change the entire wiring for the sound system? The reason I ask is that none of my speakers work except one. All the speakers are good (Checked the impedance and they are all 4ohms which is normal). The wires are all jacked up. How did they hide the wires? Are they in the floor side guards, under the carpet, or what?
I would check at the harness at the radio first. Make sure the connection there is good. I (think) the wires run along the floor at the base of the doors - but I'm not sure.
Old Dec 21, 2010 | 05:36 PM
Do you still have the OEM stereo?
Your amp might be toast.
Old Dec 21, 2010 | 05:42 PM
calebbo's Avatar
Nope, aftermarket Blaupunkt C51 Daytona Beach.
Old Dec 21, 2010 | 05:44 PM
I have no idea.
Get a hold of RoverChris, he is a 12v tech.
Old Dec 22, 2010 | 06:51 AM
hilltoppersx's Avatar
im with spike its like a foreign language.... talk to RoverChris is right...i have 9 of the 11 speakers left in my truck and only 2 are not blown.
Old Dec 22, 2010 | 11:57 AM
dansgt's Avatar
It is possible, but you'll have to see how the po wired the stereo, if they used an adaptor and the factory amp you'll basically start fresh. If he's already run new wires you've got bad speakers. I opted to run all new wiring when I did mine and it was annoying, but in the end worth it, everything is fresh and done right so yea. If it's aftermarket wiring it's hard to say where they may have run it, start by removing your stereo and see how it's running.
Old Dec 22, 2010 | 04:02 PM
calebbo's Avatar
He seemed to have used an adapter, but it's not my speakers.
They all shoot out 3.6 - 4 ohms of impedance which is normal. A blown speaker would have unlimited or something. So I'm guessing it's the wires.
Old Dec 22, 2010 | 07:30 PM
Or maybe the unit is bad.
When the stereo in my work van went belly up the left speaker stopped working, replaced the speaker no dice.
Replaced the stereo and all was well once again.
Old Dec 23, 2010 | 08:17 AM
okdiscoguy's Avatar
I would test each speaker with a known good source first, then use a known good speaker to test each output. If you are testing the speakers at the output of the deck, you may be going through the amp and reading the impedence there, not the speakers. I would still suggest testing where you can hear it. It isn't hard and you will know for sure. Then you can start running things down....
Old Dec 23, 2010 | 04:26 PM
deleon_daniel@sbcglobal.net's Avatar
Default Speakers that fit!
I just bought some speakers from wal-mart for $24 a pair three-way sound that fit perfect in the front doors and rear post. I also, used them to replace the subs in the rear door. All are working fine with no modification to the wiring or body opening.
Good Luck!
Dan
96' Disco I
154,308
