spider
Old Mar 16, 2012 | 11:00 PM
kd7hve's Avatar
5th Gear
Unhappy spider
Have 96 disco went a looked for spider unit took dash apart and were it was theirs nothing their.and cant find it any place need some help.
Old Mar 17, 2012 | 07:40 AM
Is your vehicle made for the North American Spec market? The NAS and non-NAS is different. What page in the RAVE electrical manual do you reference?
Old Mar 17, 2012 | 10:52 AM
Higgs Boson's Avatar
Your '96 is equipped with the GEMS engine management system and AS10 alarm unit. The AS10 handles the immobilization function along with the alarm. These trucks do not use the "spider". The "spider" was found in the Lucas control trucks.
Old Mar 17, 2012 | 11:05 AM
Here's a page on the 96 NAS, the alarm inhibits crank relay; but as Higgs mentioned, the ECU and the Lucas AS10 talk to each other and inhibit other things like fuel pump request, etc. The system is not made to be easy to compromise in 30 seconds by local kids. Guess these trucks cost so much new that anyone that could afford them toted around sacks of gold to pay dealer fees....
File Type: pdf
Old Mar 18, 2012 | 12:10 PM
kd7hve's Avatar
5th Gear
Smile spider
thanks guy for the quick response ok were is this thing at ,is it the one under the pass side , it has the stumble when going down the road and the alarm set and wont let it start ,got used and not key fob and here in kingman,their lucky they even know what it is .lol
Old Mar 18, 2012 | 12:15 PM
adigerol77's Avatar
KD, you say you're in Kingman. Is that Kingman az? If so, I get up in that area a couple times a month, if you need anything, let me know.
Old Mar 18, 2012 | 12:25 PM
kd7hve's Avatar
5th Gear
yea thats kingman az, i did the three key code and got it to start but would like to bye pass this thing if poss.
Old Mar 18, 2012 | 01:09 PM
kd7hve's Avatar
5th Gear
oh and thanks to all for help
Old Mar 18, 2012 | 01:23 PM
adigerol77's Avatar
Do a search, there's a thread on bypassing the spider I believe. Also where you're at you're pretty much screwed for local parts but you knew that. Good thing though, lots of great places to rover.
Another thing, before it starts to get warm, make sure your cooling system is up to snuff.
Old Mar 19, 2012 | 01:05 PM
kd7hve's Avatar
5th Gear
i got the spider bypass harness but since mine does not have one ,cause i have the nas system. so got to figure out how to bypass thiss instead
