SRS Light Bulbs
Old Mar 17, 2011 | 01:10 AM
Victoria Discovery's Avatar
3rd Gear
Default SRS Light Bulbs
I have discovered that the previous owner removed the light bulbs from the SRS light in the Dash. The Rave manual doesn't say what size or type of bulb it is. Does anyone have a part number or something I can use so I get the correct bulb.
In addition, has anyone used the new LED lights in the binnacle. How do they work? Any Problems?
1998 Discovery, Green
Old Mar 17, 2011 | 06:23 AM
Cosmic88's Avatar
Default let there be.....
Leds would be great but the voltage and wattage needs to be exact. I tried to save a few duckets by using led's instead of micro incandescents (OEM) but the only way they would work was to be precise with the ratings. I was trying to go brighter but to no avail.... maybe I'll give it more of a try than the half-hearted attempt I made with two bulbs I happened to have... it is a small and fiddly chore to remove the old bulbs from the bulb holder / base and replace it with leds but not too bad.
To your more pressing question.... this is in the tech STICKY section by the way... this is the most comprehensive chart I have found and it is VERY hard to find if you are actually trying to find it on the RN site.
http://www.roversnorth.com/store/c-3...ulbs-lens.aspx
WolfPack
Nov 7, 2008 01:41 AM
99LRDisc
Jun 30, 2008 09:41 PM
fluffdaddy
Mar 29, 2008 06:24 PM
tsuami1
Sep 20, 2007 06:18 PM
angasreid
Oct 15, 2006 04:27 PM
