SRS light staying on
Tried to install a pressure gauge in my Disco I, made the mistake of pulling the #14 fuse with key on. Now the SRS light remains on all the time. Was looking to find a fuse to tap an accessory off of. Looking for continuous 12V and thought the clock would be ideal. Now SRS is on and last "S" is blinking dimly. Any thoughts would be appreciated.
For info'
This is a dedicated circuit for the SRS system and shouldn't be tapped into.
The module controlling it all and located in the centre console monitors voltage fluctuation for optimum firing conditions for SRS deployment in case of a serious collision. Should the supply voltage be interrupted or in fact compromised/corrupted in any way it will throw an SRS code--your light will dimly blink as you have reported .
A prescribed scanner will clear the fault code which isn't on the OBD2 part of the vehicle module structure.
T/V
T/V
luxury1
Dec 31, 2008 07:57 PM
Tilt2Play
Jun 29, 2008 07:05 AM
