Stainless steel manifold inquery.
Old May 7, 2011 | 06:44 AM
ShadowMerchantBC's Avatar
Banned
Default Stainless steel manifold inquery.
My manifold is pretty rusty and old and I'm seriously considering replacing them with brand new stainless steel manifold. Problem is that few websites sell them for land rover, and any site that does sell them is located within the United Kingdom - which means the cost would be even higher with how low our USD is currently, plus shipping over sea. Does anyone know of a place or website based in the states where I could buy one?
A stainless steel manifold would only complement the stainless steel magnaflow exhaust system I'm getting in afew months.
Old May 7, 2011 | 07:09 AM
I am going to assume you mean exhaust manifolds, there is one for each side.
There is also a intake manifold.
No I do not know where you can get them.
Old May 7, 2011 | 07:28 AM
antichrist's Avatar
No idea where to get them.
Waste of money IMO.
Old May 7, 2011 | 08:11 AM
XCELLER8's Avatar
if the rust is your main concern you might want to check out Eastwood restoration products, or Mid-America corvette restoration products......they have a product that you apply as a thin paste to a rusty manifold and it eliminates the rust and gives the metal a semi-permanent new / clean look that will last quite a while.....thay use it on show cars.
I've not personally used the product but have seen the results and it really makes the metal look new, some machine shops use a similar product when they do rebuilds.
Old May 7, 2011 | 08:30 AM
Banned
Now that sounds like a good alternative! I'm assuming you still have to remove the manifolds in order to put the coating on. hmm I'm actually looking to polish up the entire engine compartment to shiny like new condition. could this stuff also be used on the engine? I'll look into this either way.
Old May 7, 2011 | 09:00 AM
jafir's Avatar
I admire your determination, but polishing or restoring an exhaust manifold is akin to polishing a turd. Just leave it. They all are rusty. I live in the south, and my D1 didn't even have the rust in the rear wheel wells that most have, but I'm sure that my exhaust manifolds were rusty.
Old May 7, 2011 | 09:10 AM
Banned
I don't know. When I see one thing wrong then I get the tenancy to want to replace everything else, and polish everything lol. Bad habit.
antichrist's Avatar
If I have them off I sand blast them and use high temp paint on them. Other than that I leave them alone.
Old May 7, 2011 | 10:08 AM
advntrjnky's Avatar
they are cast iron.....surface rust on cast iron is a protective barrier....just leave it alone.
advntrjnky
howido213
Oct 26, 2011 10:06 AM
bosshogt
Sep 9, 2010 07:31 PM
RROJ
Jul 12, 2010 09:47 PM
Aj6543
Sep 18, 2009 07:47 AM
diego rover
Oct 27, 2007 10:06 PM
