Starter Question
'98 DI w 110K
Is there anything that would cause my Rover to eat through starters? It had a new starter put on about two weeks before I got it. (back in April.) That one went bad. Put another one on in May. Now that one is bad. I know the last two were remanufactured ones supplied by NAPA for the local Firestone auto care. Just want to make sure there isn't another issue burning up the starter.
Thoughts?
Thoughts?
How's the cranking speed? If slow, then you probably have low voltage to the starter and that will shorten the lifespan of them.
Rather than reman, I suggest a Denso starter from britishstarters.com
