Starter Question
Old Aug 22, 2010 | 01:25 PM
SDraughn's Avatar
6th Gear
Default Starter Question
'98 DI w 110K
Is there anything that would cause my Rover to eat through starters? It had a new starter put on about two weeks before I got it. (back in April.) That one went bad. Put another one on in May. Now that one is bad. I know the last two were remanufactured ones supplied by NAPA for the local Firestone auto care. Just want to make sure there isn't another issue burning up the starter.
Thoughts?
Old Aug 22, 2010 | 02:37 PM
antichrist's Avatar
How's the cranking speed? If slow, then you probably have low voltage to the starter and that will shorten the lifespan of them.
Rather than reman, I suggest a Denso starter from britishstarters.com
Old Aug 22, 2010 | 07:50 PM
SDraughn's Avatar
6th Gear
Cranking speed has been normal. I think your suggestion is the best plan. I've seen a few people recommending those. Fortunately the starter is an easy swap. It just gets old doing it.
Thanks!
Old Aug 22, 2010 | 09:05 PM
Danny Lee 97 Disco's Avatar
Also look at the condition of the ground connections to the frame for both the starter and the battery. I had to redo mine.
Old Aug 23, 2010 | 06:09 AM
antichrist's Avatar
Yeah, that is one thing that can contribute to low voltage through the starter.
2005LR3SE
Feb 8, 2015 01:47 PM
99Discovery
Oct 3, 2014 09:19 AM
Gimebakmybulits
Jul 14, 2014 05:57 PM
mojosh
Sep 20, 2012 09:47 AM
johnkbl
Apr 23, 2012 07:49 PM
