Starter went out! Call the cops there gonna be.....
Old 11-20-2011 | 09:41 PM
fishEH's Avatar
Originally Posted by Discolife
It has normal bolts and I used a 13 mm and I think a 11 mm socket to screw them.
You must understand the PO installed a new engine and tranny in it in august.
The top bolt and bottom bolt are the same, exactly. The bolt diameter is 3/8", coarse(16) thread. A 9/16" socket/wrench is what would be used for a hex head bolt. A 14mm would work in a pinch.
For the original socket head screws its either a 7mm or 8mm allen wrench.
What engine/tranny did the PO install? I would be concerned that somthing isnt correct given the socket sizes you used.
Old 11-20-2011 | 09:47 PM
antichrist's Avatar
I just purchased one from Orielly was 199 but they price matched auto zone for 151.99. Lifetime warranty.
The Denso starters are new, not rebuilt, plus gear reduction. A much better starter all around.
After having one for 5 or 6 years I wouldn't even consider an OE starter.
Old 11-20-2011 | 10:08 PM
Discolife's Avatar
same thread dif head.
By scotiapilot at 2011-11-20
Old 11-20-2011 | 10:10 PM
Discolife's Avatar
Certainly a better quality starter. But since there is no store around to get this, before the start of the holidays I'll have to live with what is immediately available
Old 11-20-2011 | 11:27 PM
fishEH's Avatar
Are those the bolts that came off the starter? Those bolts look nothing like the stock bolts? What size/thread are they?
Old 11-20-2011 | 11:33 PM
Discolife's Avatar
Yes they are. It's ok. Makes removal much easier. Those Allen head bolts blow.
I don't know, it really doesn't matter as they fit and work very well. I am certain when the engine and tranny was replaced they were changed out.
Old 11-21-2011 | 06:17 AM
DiscoBlanco's Avatar
Those must be "Coffee-Can" bolts.
Old 11-21-2011 | 06:49 AM
antichrist's Avatar
Yeah.
I don't know about the top one in the photo, but the bottom one looks like a grade 2. They should both be at least grade 5.
Old 11-21-2011 | 12:34 PM
Discolife's Avatar
Easy install. Sounds great .
Ruby starts like a champ
Old 11-21-2011 | 01:15 PM
Danny Lee 97 Disco's Avatar
So the coffee can comes thru again!
Keeps us posted on Ruby's starter performance.
What did you do with the original one?
Quick Reply: Starter went out! Call the cops there gonna be.....
