Starter went out! Call the cops there gonna be.....
Old Nov 20, 2011 | 09:41 PM
fishEH's Avatar
Originally Posted by Discolife
It has normal bolts and I used a 13 mm and I think a 11 mm socket to screw them.
You must understand the PO installed a new engine and tranny in it in august.
The top bolt and bottom bolt are the same, exactly. The bolt diameter is 3/8", coarse(16) thread. A 9/16" socket/wrench is what would be used for a hex head bolt. A 14mm would work in a pinch.
For the original socket head screws its either a 7mm or 8mm allen wrench.
What engine/tranny did the PO install? I would be concerned that somthing isnt correct given the socket sizes you used.
Old Nov 20, 2011 | 09:47 PM
antichrist's Avatar
I just purchased one from Orielly was 199 but they price matched auto zone for 151.99. Lifetime warranty.
The Denso starters are new, not rebuilt, plus gear reduction. A much better starter all around.
After having one for 5 or 6 years I wouldn't even consider an OE starter.
Old Nov 20, 2011 | 10:08 PM
Discolife's Avatar
same thread dif head.
By scotiapilot at 2011-11-20
Old Nov 20, 2011 | 10:10 PM
Discolife's Avatar
Certainly a better quality starter. But since there is no store around to get this, before the start of the holidays I'll have to live with what is immediately available
Old Nov 20, 2011 | 11:27 PM
fishEH's Avatar
Are those the bolts that came off the starter? Those bolts look nothing like the stock bolts? What size/thread are they?
Old Nov 20, 2011 | 11:33 PM
Discolife's Avatar
Yes they are. It's ok. Makes removal much easier. Those Allen head bolts blow.
I don't know, it really doesn't matter as they fit and work very well. I am certain when the engine and tranny was replaced they were changed out.
Old Nov 21, 2011 | 06:17 AM
DiscoBlanco's Avatar
Those must be "Coffee-Can" bolts.
Old Nov 21, 2011 | 06:49 AM
antichrist's Avatar
Yeah.
I don't know about the top one in the photo, but the bottom one looks like a grade 2. They should both be at least grade 5.
Old Nov 21, 2011 | 12:34 PM
Discolife's Avatar
Easy install. Sounds great .
Ruby starts like a champ
Old Nov 21, 2011 | 01:15 PM
Danny Lee 97 Disco's Avatar
So the coffee can comes thru again!
Keeps us posted on Ruby's starter performance.
What did you do with the original one?
