steamin exhaust
Old Jul 5, 2012 | 07:58 AM
TOW's Avatar
TOW
5th Gear
Default steamin exhaust
hi all
can anyone diagnose this.
new coolant pump fitted
now occasionally emits steam from exhaust
coolant level static and uncontaminated
oil same
is it the head gasket?
or something i am missing?
my brain is spinnin !
Old Jul 5, 2012 | 08:02 AM
might be condensation at warm up, might be very small leak. chemical test for exhaust gas in coolant?
Old Jul 5, 2012 | 08:04 AM
filbs's Avatar
From what I understand it is normal to have some steam in exhaust.... You said you arent losing coolant right? if that is the case I wouldnt jump to HG. Once again I am no expert, just basing this on what I have learned from the gurus here.
Old Jul 5, 2012 | 09:00 AM
TOW's Avatar
TOW
5th Gear
Default hot
this steamin only happens after 5 miles of running
Old Jul 5, 2012 | 09:30 AM
ToddD's Avatar
Compression test engine and cooling system.
Remove and inspect condition of spark plugs. Look for one that's different than the rest. Keep them in order when you remove them. One will be steamed clean if you have coolant getting into the cylinder.
Could be head gasket or intake manifold gasket.
You won't know until you do more testing.
Old Jul 5, 2012 | 10:10 AM
TOW's Avatar
TOW
5th Gear
thanks Todd but its a diesel
Old Jul 5, 2012 | 10:12 AM
TOW's Avatar
TOW
5th Gear
i suppose it might be a tiny crack in the head
Old Jul 5, 2012 | 11:11 AM
ToddD's Avatar
well.... don't bother pulling the spark plugs. ha ha.
I want a diesel disco...
Old Jul 5, 2012 | 11:40 AM
TOW's Avatar
TOW
5th Gear
diesel is great but the coolant pump bearing broke and seal went ,dumped all the coolant. i think i have damaged the gasket or the head !!
(i didnt look for the spark plugs haha)
robdis96
Headers, Intake, & Exhaust
53
Dec 20, 2013 07:11 AM
twaszak
Jul 15, 2012 07:21 PM
Street Wolf
Jun 24, 2011 01:59 AM
Viper3812
Sep 13, 2007 05:33 PM
beavis4g63t
Jul 12, 2005 05:27 PM
