Steering box leak?
Old Jul 21, 2023 | 05:47 PM
Fastercat's Avatar
Default Steering box leak?
Hi guys, my 94 has been leaking steering fluid since I got it, I assumed it was the hoses so I replaced all 3, but it appears to be coming out the side of the box??? Is this possible?
Old Jul 21, 2023 | 05:49 PM
Fastercat's Avatar
It appears to be on the frame side where I can’t see
Old Jul 21, 2023 | 09:11 PM
outono's Avatar
Very possible and common. You can rebuild yourself, which isn't too hard if you're comfortable with mechanical work, you can have it rebuilt by a professional, or you can buy a new from BuyAutoParts, which is just a rebuilt unit out of E. Asia - your unit may be decent quality or crap (mine was crap).
Old Jul 23, 2023 | 10:52 AM
JohnZo's Avatar
Maybe spray it down with brake cleaner and see if you can pinpoint the leak better. There are several seals that could potentially leak, and seal kits are available. I re-built one, not too difficult and a learning experience. I followed the Workshop Manual.
Old Jul 23, 2023 | 10:39 PM
Harvlr's Avatar
I also rebuilt my PS Pump in my D2 with great success, but there were a couple of tiny parts inside that I wasn’t aware of and that I was lucky not to lose. As said above, it’s easy to rebuild. If you’re replacing the bearing a press would be handy. (The bearing replacement isn’t necessary to repair your leak).
bmeier
Apr 27, 2026 05:26 PM
Massrover
Dec 4, 2022 11:31 AM
lestro
Jun 21, 2021 05:13 AM
paul40269
Sep 5, 2016 12:45 PM
chrisusvi
Jan 29, 2009 05:54 PM
