Steering problems HELP!!!
Old Oct 24, 2011 | 02:40 PM
DiscoGrlNC's Avatar
Default Steering problems HELP!!!
2003 LR Disco SE7 - replaced steering pump. 2 different gearboxes installed. Repl 1st steering pump and gearbox as box was pouring PSF and ruined pump. New Pump and reman gearbox. Now, steering loose in straight position and intermittently while making right turns, the steering wheel will "stick" and "pop" into turning when you force the wheel past the sticking point. Was told gear box bad, but be missing a tooth in the gear itself, so replaced the box today with another. Doing the same thing now, only a little further into the right hand rotation than before. HELP!!!
Old Oct 24, 2011 | 03:42 PM
Is mechanic doing the work "centralizing" the steering, then following the adjustment procedure in the RAVE? Both boxes rebuilts?
LICKDLISH
Mar 17, 2017 10:28 AM
Frank4
Mar 21, 2014 05:21 AM
bnentrup
Oct 22, 2013 05:52 PM
dh42891
May 28, 2008 04:58 PM
RSweet
Jul 3, 2007 09:03 AM
