Steering Shake/Wobble At 70MPH
Old Jun 26, 2010 | 01:41 AM
Spencerfitch's Avatar
Default Steering Shake/Wobble At 70MPH
I usually drive on interstates which the speedlimit is 70 miles per hour. I at first though it was a problem at speed at and above 70mph, then the other day I was feeling a little sporty and got up to 80...... maybe even 90
Well, the wobble went away. Only at 68-73mph does it occur.
Other symptom is its not constant. What would make a wheel wobble for 1 minute then go away for 1 minute?
I know the basics, drive shaft, wheel weights, etc. But what would make it wobble at a certain speed and on and off.
Old Jun 26, 2010 | 05:13 AM
Long Haul's Avatar
usually from my experiance with that has always been wheel out of balance...try rotating your tires and see if it goes away
Old Jun 26, 2010 | 07:40 AM
antichrist's Avatar
In your other thread you say you need bushings. I'd replace all your suspension bushings then see how it is and go from there.
Old Jun 26, 2010 | 07:56 AM
That is a tired truck, do a Tom mentions, after you have balanced and rotated the tires, then start looking at all your bushings, tie rod ends, wheel bearings and swivel pre-loads.
Old Jun 26, 2010 | 11:02 PM
greg409's Avatar
ditto what Mike said, if it's the confidence inspiring, beloved "death wobble", it's likely tie rod ends or swivel preload/bearings.
Just about all the other reasons are not so speed specific.
It's not the steering damper.
luck,greg
Hawkeye712
Jul 21, 2015 06:59 PM
aBs0lut30
Mar 31, 2015 10:43 AM
bradman951
Apr 14, 2014 10:10 PM
jeffh
Jan 20, 2011 12:35 PM
kenk
Feb 15, 2010 09:51 AM
