Steering / Track Rod End advice
Old Aug 9, 2014 | 09:59 AM
archaeology_student's Avatar
Question Steering / Track Rod End advice
Just wondering how bad my Track Rod End looks? I swear that's not my oil in the picture... that's some other vehicle
Old Aug 9, 2014 | 12:21 PM
TOM R's Avatar
Press em out install urothane
Old Aug 9, 2014 | 12:42 PM
fishEH's Avatar
The TRE attached to the steering drop arm looks wonky. Grab it with your hand and move it. If it's loose/sloppy then replace it.
Old Aug 9, 2014 | 12:47 PM
Talking
Tom, appreciate that, but I am focussing on the track rod end / tie rod / ball joint in the photo... seems like it has a few aliases lol
#9 in the diagram below
Old Aug 9, 2014 | 04:27 PM
geek_IM's Avatar
That rubber boot is the key pretty much. If it is still intact ie no rips or holes and is still full of grease that you can squish around you should be ok. They mostly go bad when they are dry for a while. If it is a good one it should have a grease nipple so you can add more.
Other than that you should also look for any play in the ball joint. Jack it up and have someone horse the tire around a look for movement in the joint.
Old Aug 9, 2014 | 04:46 PM
TOM R's Avatar
Sorry I keep forgetting rover calls parts what they want
Lay under and watch as someone rocks the wheel back and forth engine off you will see all loose joints very clearly
Old Aug 11, 2014 | 01:10 PM
Is it me, or does mine look like it is bent/crooked and about to break in the photo?
Old Aug 11, 2014 | 01:16 PM
fishEH's Avatar
What's the other end look like? TRE's are designed to pivot on the ball inside. You should be able to take the whole bar and "roll" it forward and back and both TRE's should pivot the same.
Old Aug 11, 2014 | 03:00 PM
socal1200r's Avatar
If you do need new TRE's, I say go for broke and get the HD steering rods with the TREs already installed from Lucky 8. That was the advice given to me, and man, those things are heavy duty, emphasis on heavy! I replaced the steering stabilizer while I was at it, stock location, but at least I know the rods, TREs, and stabilizer are new and good to go.
calebbo
Nov 13, 2011 09:41 PM
bschoole
Aug 4, 2011 03:56 PM
RjBu
May 31, 2011 01:32 PM
Rovinfool
Aug 26, 2010 04:09 AM
kenk
Oct 7, 2009 07:59 PM
