HD drag and track rod installation
Old May 24, 2011 | 03:34 PM
RjBu's Avatar
Default HD drag and track rod installation
Hey guys,
I got a new set of HD steering gear and was curious if I needed to jack up the truck in order to do it? With the lift and tires i have plenty of room but was curious if there was an advantage to jacking it up for the procedure? I can already hear.. "why wouldn't you" long story short it would be of considerable benefit for me to leave her planted on the ground. Thoughts?
Old May 24, 2011 | 03:52 PM
BackInA88's Avatar
I put mine on with all 4 wheels still on the ground.
Old May 25, 2011 | 08:59 AM
RjBu's Avatar
Thanks for the that Steve! Did you use a pickle, pusher, or hammer to free the original TRE's?
Old May 26, 2011 | 06:57 PM
malmberg's Avatar
I just did mine last weekend and it came off fairly easy with the pickle fork. I noticed that I will a new bolt for the steering stabilizer since the bracket was beefier than stock.
Old May 27, 2011 | 08:11 AM
RjBu's Avatar
Thanks for the heads up! What kit did you install? Also do you happen to know what sized bolt you needed?
Old May 31, 2011 | 01:32 PM
malmberg's Avatar
I ordered mine from lucky8, they make their own now. The rods are grey and they look great. I havent had any luck finding the bolt yet. I will probably have to order one online. If anyone else knows this bolt size please let me know.
MuleyJ
Aug 15, 2012 11:33 PM
mx930
Nov 7, 2010 06:39 PM
kenk
Oct 7, 2009 07:59 PM
malmberg
Aug 9, 2009 07:57 PM
bmwrovers
Jun 4, 2009 06:17 PM
