Substitute Fuel Pressure Regulator
Old Jun 16, 2023 | 09:07 PM
JohnZo's Avatar
Default Substitute Fuel Pressure Regulator
Can someone remind me the make/model of the Volkswagen or BMW fuel pressure regulator that fits our D1 trucks? I recall one of the main posters here uses the substitute for higher fuel pressure. My 96 needs a new unit.
Old Jun 17, 2023 | 05:38 PM
Best4x4's Avatar
It will fit 94-97 D1's without AEL. I'm at a dance recital with poor cell service but I'll post the P/N when I get a better signal. Yes it is from older BMW/VW's.
Old Jun 18, 2023 | 08:53 PM
Best4x4's Avatar
PR60 is the P/N I've used in the past or BOSCH 280160226. That'll get you the higher flow unit that works on all 87-97 RRC/D1's without AEL.
Old Jun 19, 2023 | 07:59 PM
JohnZo's Avatar
Best, thanks for the help. I ordered a Delphi (p/n FP10302) unit from Rock Auto for $64 plus tax & shipping. Rated 3.0 bar, specified for a 1993 BMW 325i. Original LR spec is 2.5 bar. There were cheaper options available, but the photos and brand for this one impressed me. It has shipped via USPS, so I'll let you know how it works out.
Old Jul 9, 2023 | 02:32 PM
JohnZo's Avatar
Been driving with new fuel pressure regulator. First three to six drive cycles had some back firing during deceleration, especially driving up to a stop sign. Now it seems ECU has adjusted to the new pressure, no more back firing. To soon to judge impact on fuel economy. It drives great.
Tested the original Lucas pressure regulator using compressed air and a hand vacuum pump, it is right on spec, about 34 psi with 15 inches Hg vacuum, 41 psi with no vacuum. New regulator should be about 7 psi higher.
Old Nov 4, 2023 | 09:41 AM
JohnZo's Avatar
Update: Higher pressure regulator (3.0 bar, 44 psi) still causes backfiring during warm up drive cycle, mostly when engine coolant temperature is around 100 deg F, before the engine fully heats up but is not cold. It was bad enough to set CEL codes for misfire, so decided to change back to original spec 2.5 bar (36 psi).
abfoster
LR2
Mar 27, 2023 12:06 AM
ESPN
Dec 4, 2013 12:13 PM
Akumal
Nov 6, 2012 03:04 PM
robertnsmith
May 3, 2011 11:52 AM
mac25dm
Sep 6, 2007 10:23 AM
