Sunroof making wind noise
Hi,
I just bought a land rover discovery 1, year 98. The sunroof works and doesn't leak, but when I am driving on the highway after 60 mph, it sounds like you are in a wind tunnel. There is not much air coming in, almost nothing but sound is too much. I took it to a mechanic and he suggested replacing the whole sunroof and its glass, for a cost of $800. Can anyone suggest a cheaper option? I can even consider sealing it shut permanently since I don't see much of a use for it that is worth $800.
Best.
Best.
Thank you for your answer. One mechanic says frame is warped, needs to be replaced, the other one says frame is fine, seal needs to be replaced. I am getting really confused and not sure how competent these mechanics are. Does anyone have any guidance about how to diagnose this? If anyone knows a good mechanic in the seattle or vancouver area, that would be great too.
If you are new to Discovery 1's, you need to know that all sunroof's leak at some point. And there doesn't appear to be an easy fix unless you replace the whole unit which will run you near a grand. Mine leaks and I am trying to find a solution. I've been quoted $500 for a fix but that is with using the rails from a salvage, so there is no guarantee it will be completely secure long term.
I wish more people would chime in as to a reasonable solution to the sunroof issue but there doesn't appear to be one at the time.
There is also the issue of dropping the headliner when replacing the rails or unit. This in itself can cause problems, headliner backing bends, cloth comes loose, etc. It's a giant headache.
4.6HSE
10-19-2010 11:08 AM
cheatham25
02-16-2007 11:14 AM
cmitty
12-20-2005 01:36 AM
