Sunroof making wind noise
Old Apr 17, 2016 | 10:55 PM
nzt's Avatar
nzt
6th Gear
Default Sunroof making wind noise
Hi,
I just bought a land rover discovery 1, year 98. The sunroof works and doesn't leak, but when I am driving on the highway after 60 mph, it sounds like you are in a wind tunnel. There is not much air coming in, almost nothing but sound is too much. I took it to a mechanic and he suggested replacing the whole sunroof and its glass, for a cost of $800. Can anyone suggest a cheaper option? I can even consider sealing it shut permanently since I don't see much of a use for it that is worth $800.
Best.
Old Apr 18, 2016 | 11:58 AM
WaltNYC's Avatar
ebay or one of the dismantlers in the vendor section
Old Apr 18, 2016 | 10:47 PM
nzt's Avatar
nzt
6th Gear
Thank you for your answer. One mechanic says frame is warped, needs to be replaced, the other one says frame is fine, seal needs to be replaced. I am getting really confused and not sure how competent these mechanics are. Does anyone have any guidance about how to diagnose this? If anyone knows a good mechanic in the seattle or vancouver area, that would be great too.
Old Apr 18, 2016 | 11:02 PM
Honeyrider's Avatar
There's definitely plenty of threads on this forum as to how to remedy the sunroof. Having said that, if you insist on taking it to a mechanic Rovalutions in North Van I hear is pretty good. There is also Hesp Auto in north Van. Check out their sites. I can't speak for their work personally as I have always done my own work. Goodluck dude.
Old Apr 21, 2016 | 09:51 PM
stillruns's Avatar
I don't believe it is your sunroof. Do you have the cross bars on your roof? The black rails that cross the roof for luggage, etc. Maybe it's those that make the noise and not the sunroof. Take them off and see.
Old Apr 22, 2016 | 01:54 AM
nzt's Avatar
nzt
6th Gear
I have been checking this myself and I think there is a leak in the sunroof. I saw the water coming in at the car wash. Not sure how to fix it, but I ordered seal online and I will try to install it myself.
Old Apr 22, 2016 | 06:37 PM
stillruns's Avatar
If you are new to Discovery 1's, you need to know that all sunroof's leak at some point. And there doesn't appear to be an easy fix unless you replace the whole unit which will run you near a grand. Mine leaks and I am trying to find a solution. I've been quoted $500 for a fix but that is with using the rails from a salvage, so there is no guarantee it will be completely secure long term.
I wish more people would chime in as to a reasonable solution to the sunroof issue but there doesn't appear to be one at the time.
There is also the issue of dropping the headliner when replacing the rails or unit. This in itself can cause problems, headliner backing bends, cloth comes loose, etc. It's a giant headache.
4.6HSE
Oct 19, 2010 11:08 AM
snapped
Nov 29, 2007 09:06 AM
discoken
Aug 28, 2007 10:04 AM
cheatham25
Feb 16, 2007 11:14 AM
cmitty
Dec 20, 2005 01:36 AM
