suspension question
suspension question
Ok so this may seem like an idiot question.
I have both a 97 Disco 1 and an 89 classic range rover.
I got into an accident with the disco, and the transfer case on the 89 range rover is shot. The idea is to take both the axles off the disco and put them on the range rover classic. I was told that this may be possible because many of the parts on the disco are interchangeable with the range rover classics.
if the gear ratio matches I will probably just switch the front, any ideas will this work at all?
Wth?
http://www.toddcosuspensions.com
Drop them a line, they would be able to help you out in what will interchange with what, and what else may be needed, if anything, to make it all work.
fastrx7man
01-28-2012 12:49 PM
