suspension question
Old Oct 1, 2010 | 06:25 PM
qtkoral's Avatar
3rd Gear
Default suspension question
Ok so this may seem like an idiot question.
I have both a 97 Disco 1 and an 89 classic range rover.
I got into an accident with the disco, and the transfer case on the 89 range rover is shot. The idea is to take both the axles off the disco and put them on the range rover classic. I was told that this may be possible because many of the parts on the disco are interchangeable with the range rover classics.
if the gear ratio matches I will probably just switch the front, any ideas will this work at all?
Old Oct 1, 2010 | 09:34 PM
kenk's Avatar
Just measure up the width, spring pearch spacing, control arm mount spacing,etc and see if it all matches up. I'm betting RR axles may be a little wider. But may not.
Old Oct 4, 2010 | 02:47 PM
qtkoral's Avatar
3rd Gear
your in jamestown? I am in sag harbor, NY. hopfully we can figure something out. thanks for the feedback
Old Oct 4, 2010 | 03:24 PM
leadfoot's Avatar
Lightbulb Wth?
The transfer case is shot on the RR so you are going to replace the axles from the LR to the RR
Old Oct 5, 2010 | 09:54 AM
qtkoral's Avatar
3rd Gear
Yes, the transfer case and the front end are shot. So the idea is to replace both.
Old Oct 5, 2010 | 03:16 PM
kenk's Avatar
http://www.toddcosuspensions.com
Drop them a line, they would be able to help you out in what will interchange with what, and what else may be needed, if anything, to make it all work.
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
Aaron Sandland
Feb 12, 2015 09:35 AM
fastrx7man
Jan 28, 2012 12:49 PM
FlyUgly
Aug 3, 2005 01:41 AM
