Sway / Wandering
Old Dec 7, 2018 | 03:26 PM
emtuzas's Avatar
Default Sway / Wandering
Hello again,
Replaced all 3 rods on the front with new ball joints and so on, got alignment done, however - when driving faster seems like the steering wheel feels a bit loose and the car tends to wander around / sway more than i would like it too.
It has a 2" OME LIFT kit installed if that changes anything. Any ideas on what to look for? Its not terribly bad, but seems like something's off a bit. Wheel bearings also replaced.
Old Dec 9, 2018 | 09:26 PM
XCELLER8's Avatar
check out the panhard rod / bolts/ bushings.............the bolts that hold it in the suspension brackets need to be gawd-awful tight...personal experience
Old Dec 10, 2018 | 01:13 PM
fishEH's Avatar
Was it doing this before the lift? Before the steering rods and tie rod ends replacement? Narrowing down exactly when it happened will help with diagnosis. Since you say "Replaced all three rods" I'm assuming you did the panhard?
Originally Posted by emtuzas
Hello again,
me 2
Oct 5, 2016 03:48 AM
Yeti
Oct 21, 2013 05:17 PM
98HSE46
16
Feb 26, 2013 04:03 PM
adamlanders
Nov 3, 2011 09:59 PM
JamesDisco97
Sep 8, 2011 10:54 PM
