Switch window up/down : diode replacement
Old Aug 25, 2019 | 02:48 PM
Pierrodisco's Avatar
Question Switch window up/down : diode replacement
Good evening !
When switching front lamps on, all 4 those switches on central panel between driver and passenger are illuminated. However, in one switch, the specific diode is blown. So I took out the switch and carefully with a smell screwdriver parted the two black plastic components. The diode has a green soft plastic transparent cover that can be taken off, but when raising the diode out of his socket, both electrical conducts are broken ! What are the specifications for that diode ? And where can I buy it
Showing the diode (between soft green cap and switch) withouten broken contacts.
Old Aug 26, 2019 | 06:40 AM
WaltNYC's Avatar
here are the bulbs...
Amazon Amazon
and the rubber boot...
Amazon Amazon
Old Aug 28, 2019 | 11:41 AM
Thumbs up
Originally Posted by WaltNYC
Thank you very much for the information !
I think the same problem/solution for the illumination of both switches for air/co and intern circulation of air in the ventilation panel of met Disco !
Kind regards !
Old Feb 20, 2020 | 11:05 AM
Smile Bulbs made by Memotronics
For the members in Europe,
CEC Industrues does not ship bulbs to Europe !
So I found Memotronics on the web ; the firm does ship bulbs with exact the same caracteristics to Europe (by Amazon).
so I can starting my work !
Old Feb 21, 2020 | 06:06 AM
JUKE179r's Avatar
Would a D2 window switch work in a D1?
Old Feb 21, 2020 | 10:49 AM
Hello,
As good as I’m informed, early D2’s have a lot of components common with the latest D1’s !
At first sight at your picture, I woud say, yes.
But let me first repair the switch of my D1, so I can carefully in detail compare both switches.
I ‘ll post a message about it over a week !
See you,
PierroDisco
Old Feb 24, 2020 | 03:05 PM
Thumbs up Bulb replacement succeeded !
Good evening,
I’ve replaced the blown bulb in the window switch...and it gives now a bright backlight. Remark that the replacing Metronomics bulbs aren’t as great as about 2/3 of the Lenght/Width of the original bulbs, but you can carefully slide the reused green boot, now a lot to large, over the new bulb.
But now I think the “inside” of my switch doesn’t meet the details of your picture ; my bulb and boot are completely drown in the black socket, not as yours, and so some other details “at first sight” different.
Maybe, you can learn about the switch socket from this picture !
Old Feb 25, 2020 | 08:29 AM
Thumbs up Trying to attach the picture !
Hello,
Yesterday evening, I couldn’t load the picture (to many Mb’s and format bot supported - HEIF, token with Apple Notepad).
So, I saved the picture as ZIP-file.
maybe it does load now (under attachments)
LR4Noco
LR4
Mar 6, 2019 12:27 PM
KingKoopa
Oct 12, 2017 11:26 PM
LandIdaho
Feb 5, 2017 09:00 PM
azsparrow
Aug 23, 2016 12:28 PM
justfred
Mar 12, 2007 10:20 PM
