Swivel balls scored? Need seals?
Swivel ***** scored? Need seals?
I excersized tremendous restraint when thinking of a title. (you know who you are)
Anyway, a couple of years ago, I read on the brits forum about repairing gouges in my *****, as well as on vehicle replacement of leaking rubber
seals.
They rcommended hacksawing the new seal to split it after removing the spring inside.
That would effectively remove metal, so I:
removed the spring from the new seal, then find the split where it's screwed together (magnifying glass) unscrew it.
I cut the new seal with a GOOD pair of aviator tin snips (thru' rubber & steel) in one spot.
Now to the injured ball - (cut off old seal and holder removed but left dangling) I brakecleaned the crap out of the surface, then mixed up some 24hr jb weld.
I spead jb into gouges with a stiff but flexible piece of plastic.
Keep it pretty, but put plenty on it.
Go away and come back tomorrow.
I then used a small file to rough contour it, followed with some 600grit in my palm. (yes, my hand)
When it looked pretty, i took a chunk of the old seal and check shape.
I then contorted new seal into place (no kinking allowed), wrapped spring around and re-wound it back, then installed it onto new seal.
I put rtv around cut in seal (now at top) and re-installed.
filled ball with one shot (ebay $15/two tubes)
There you go, 10k later, still good.
luck,greg
seals.
luck,greg
gouges in my *****,
Now to the injured ball left dangling
They say when you think you used too much thats almost enough
(no kinky allowed),
I've wondered that too. When I rebuilt my swivel *****, I had a couple minor scores/pitts that I filled with standard 2 part epoxy resin, then sanded smooth.
The only part physically touching the swivels is the rubber oil seal. So I'm guessing either corrosion and/or debri getting caught in the rubber seal.
You people are too predicktable - funny tho'
Some times mud, rocks get under the rubber seal, causing irritation, increasing to scratching, surface damage.
Imagine having a piece of gravel held tightly to a ball, pretty soon it may start leaking.
Ok, that's enough for me
Kenk, you're 100% correct, I was surprised the chrome hadn't started to delaminate.
Common wisdom says do NOT use the gaitor covers unless you remove regularly to clean underneath PITA
luck,greg
luck,greg
