Swivels (and small suspension question)
Old Oct 27, 2013 | 07:53 AM
antichrist's Avatar
The swivel ***** for ABS and non-ABS are different part numbers, I'm assuming because the upper bearings and pin are different.
FTC5105 - ABS
FRC7065 - non - ABS
Old Oct 27, 2013 | 10:54 AM
calebbo's Avatar
FTC5105 - ABS
FRC7065 - non - ABS
So does that mean the non abs won't fit my swivel ball?
Old Oct 27, 2013 | 11:19 AM
antichrist's Avatar
I believe that's correct. I have both ABS and non-ABS rebuild kits in the garage, I'll try to check dimensions today.
Old Oct 27, 2013 | 11:35 AM
calebbo's Avatar
Thank you. Next question is:
I have ABS swivels. So I need tapered bearings top and bottom for swivel ball.
Top swivel pin needs to be ABS only (new info). So I still use needle bearing and two thrust washers on top with shims correct? So in this order from top down: top swivel pin, shims, washer, needle bearing, washer, swivel ball. Am I good so far?
Old Oct 27, 2013 | 06:33 PM
Originally Posted by XCELLER8
I have to replace the swivel ball it self since its' all pitted....it pukes grease all over the wheel..so Im goin deep.....
Screw that.
Buy the gaitor kit, its a rubber boot that goes over and seals the swivel *****, your swivel's will look like a DII's CV joint.
Install the kit, no more leaks, I did this over a year ago, takes about a hour, water tight, works great and I highly recommend it.
Old Oct 27, 2013 | 09:43 PM
XCELLER8's Avatar
Spike, is that the kit that's on ebay ?
Old Oct 27, 2013 | 10:52 PM
jafir's Avatar
You can actually buy it from land rover too.
RTC3826
Personally I'd use it to protect the seals and housing surfaces from damage before they start leaking.
Old Oct 28, 2013 | 04:20 AM
antichrist's Avatar
No, Tapered roller bearing on the bottom only.
That sounds right, but double check the manual.
Old Oct 29, 2013 | 04:51 PM
antichrist's Avatar
I couldn't find the rebuild kits. I must have boxed them up and stashed them on a back shelf.
Old Oct 30, 2013 | 08:23 PM
calebbo's Avatar
Alright, I've been busy with work and school so the Landy is still missing her front end practically. I'll get with Trevor and figure this out and make a write-up.
