Swivels (and small suspension question)
So does that mean the non abs won't fit my swivel ball?
Thank you. Next question is:
I have ABS swivels. So I need tapered bearings top and bottom for swivel ball.
Top swivel pin needs to be ABS only (new info). So I still use needle bearing and two thrust washers on top with shims correct? So in this order from top down: top swivel pin, shims, washer, needle bearing, washer, swivel ball. Am I good so far?
Buy the gaitor kit, its a rubber boot that goes over and seals the swivel *****, your swivel's will look like a DII's CV joint.
Install the kit, no more leaks, I did this over a year ago, takes about a hour, water tight, works great and I highly recommend it.
You can actually buy it from land rover too.
RTC3826
Personally I'd use it to protect the seals and housing surfaces from damage before they start leaking.
RTC3826
