Tacho not working. Test proceedure????
Old Jul 8, 2010 | 08:04 PM
dogs55's Avatar
Default Tacho not working. Test proceedure????
Hi guys, my tacho stopped working yesterday. Is there a way to test alternator for fault before forking out for new one.
Thanks
Old Jul 8, 2010 | 08:30 PM
Yes there is, with the truck running check the voltage at the battery terminals with a volt meter.
But you need a new alternator.
Old Jul 9, 2010 | 11:55 AM
johnkbl's Avatar
Turn on your truck, then disconnect the battery with the car running. If the alternator is not providing energy, the engine will stop. Otherwise you would have to check the white/brown wire that is connected to the back of the alt.
Good luck!!
Old Jul 31, 2010 | 06:45 PM
dogs55's Avatar
Cheers. rectifier is toast. Not too sure about regulator. Is it worth rebuilding. It is a magneti Marelli, A127i-100 amp. Part# AMR3107. If not worth rebuilding whats the most reliable replacement option and from where.
Old Jul 31, 2010 | 08:26 PM
XCELLER8's Avatar
if you have reliable rebuild shop locally....I would definitely let them reman it....other guys here have complained that if you get a "rebuilt" one from auto zone ( or the others ) you will get crap and it will only last a year or so if you're lucky.
Old Jul 31, 2010 | 09:34 PM
Yes it is def worth rebuilding.
If you dont rebuild yours then buy a new one, Bosch makes new ones too and are cheaper than the MagNelli's.
Old Aug 1, 2010 | 04:35 PM
Danny Lee 97 Disco's Avatar
Rebuild it!!!
tsuyoi
Sep 22, 2020 10:37 AM
umoms
Apr 3, 2008 06:22 PM
scotty_308
Jul 4, 2006 01:37 AM
