Tail light melted again - no contact - whats the fix
Old Aug 28, 2023 | 07:39 AM
whiskeynipple0088's Avatar
Default Tail light melted again - no contact - whats the fix
What is the fix for this. I would like a once and done solution even if that mean modifying the existing housing to accept a different socket that uses leads. Or mount a LED type on the outside and thread the leads thru.
I cant seem to find any LED break and running lights that are small enough.....
Thoughts?
Old Aug 28, 2023 | 03:07 PM
JohnZo's Avatar
Here is what I did. I use LED replacement bulbs I bought from AutoZone. Sylvania or Osram made to replace 5/21 or 21 watt incandescent bulbs (codes 1056 and 1057 as I recall). Correct brightness, equivalent wattage, but much cooler so will not burn or melt the sockets. I am sure LED replacement bulbs are available at other stores too.
I replaced all the bulbs, but really only needs the tail lights (dual filament 5/21 W, 5W running plus 21W brake), because running stays on continuously at night, then when the brakes are on totals 26 Watts and causes the melting. Reverse light doesn't need LED, unless driving in reverse for hours. Turn signal doesn't need LED, blinking helps it stay cooler, but LED will last longer than incandescent. The turn signals still flashed properly with the LEDs, so I didn't need to add load resistors.
Hope this helps.
Old Aug 28, 2023 | 06:17 PM
thanks Johnzo - yeah I should have installed LED bulbs, problem now is the housing is warped and will not allow socket to seat correctly to make contact. And holy cow are prices ridiculous.... when I replaced the assembly before it was $40 now people want $130.....
Old Aug 29, 2023 | 02:34 PM
WaltNYC's Avatar
are you talking about these?
https://www.roverparts.com/electrica...ights/AMR6509/
Old Aug 29, 2023 | 09:48 PM
JohnZo's Avatar
So, a bit more than a tank of gas...
Puts it in perspective. Eventually there won't be any more to find.
Old Sep 1, 2023 | 08:12 AM
Originally Posted by WaltNYC
No - the pillar lights.
Ive ordered some AC Delco sockets with leads and intend on modifying the housing and connecting the leads via spade connectors to the exposed traces on the back of the housing. Also think Im going to install reflective tape inside the housing to hopefully cut down on the warping.
Im unclear on the real solution with LED bulbs. "Hyperflash and load equilizer" - also reading they are not as many lumens.
chandlerhayes01
Apr 11, 2022 10:51 AM
chipstar5000
Sep 30, 2021 06:15 AM
Unshriven
Feb 27, 2012 05:31 PM
primey
Oct 5, 2011 10:06 PM
fluffdaddy
Mar 29, 2008 06:24 PM
