thick oil on lower engine and left tie rod
i will take a picture if needed. I don't know whats leaking. car used to have bad power steering leak but not any more. the mystery black stuff is shinny some places. I have been checking oil and it has not gone down. Mom said she has never added oil her whole ownership (4 or 5 years
) so I checked and it was way under low. added oil have been checking it it has not gone down (noticeably down)
I was wondering should I degrease to see if there is still a leak and or where its coming from
![EEK!](https://landroverforums.com/forum/images/smilies/bmHv6Xb.png)
The problem with power washing these engines if that the electronics can get wet and then it is game over. The ECU is on the left fender, also the alt can get wet and quit. That's why everyone on here says it is safest to stay away from power washing. That being said I power washed the area around my power steering pump and my front axle being very careful of which way I pointed the stream. Everything else I cleaned by hand. So pick your poison but be very careful. Has the routine maintenance been kept up on your disco? Such as coolant changes, oil changes, diff oil changes, air filter changes, oil filter changes, UJ's greased regularly, etc? If not I would suggest you get on the 60K service sticky asap or you will find that it goes downhill quick. If you don't really want to spend much time with your disco you probably should sell it for something else. These things are like a high maintenance girlfriend.
ok I will tell the owner now. I was telling her that it really needed a trip to land rover. but she will be more willing if I show her your reply. I guess I'm lucky because I did a engine clean when I added the oil and power steering. it only cleaned the top half of the engine. if I showed you a picture the stuff is really thick. I will take pic's tomorrow.
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
have to check the miles i will say its way over 200,000 and she knows to put premium in it. its funny that you bring that up. I have been telling her for the longest to put that in it and the reason she doesn't hear knocking is because it has a sensor to prevent knock she has somehow convinced me to use a cheaper gas
![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
