Throttle linkage cables
Old Apr 2, 2016 | 03:13 PM
diggerod's Avatar
Default Throttle linkage cables
There is a cable beneath the throttle cable that I'm not sure what it is. It hooks into the transmission on top, mine got hot up against the exhaust manifold and melted the casing and doesn't move. I tried soaking pb blaster down it to loosen it up, but no luck. So iI need to order a new one, but not sure what to order.
Old Apr 2, 2016 | 03:22 PM
diggerod's Avatar
Is it the kick down cable? If it is can I just run it with out it. I use this for off road only. What does it actually do?
Old Apr 2, 2016 | 03:43 PM
diggerod's Avatar
It Is the kick down cable, Says it should be taken to a dealer to replace. And I'm not doing that, says you need a special tool to unhook from the trans. Can it be done without the tool?
Old Apr 3, 2016 | 10:18 AM
diggerod's Avatar
found a little more info on it and seems to be an all day job. I'm still trying to figure out if I can run it unhooked since the truck really never comes out of 2nd gear in the tight woods. Has anybody ever done this?
jeepingpw
Feb 23, 2014 04:22 PM
SenatorPerry
Jul 15, 2013 10:28 AM
focusontheworld
Nov 4, 2012 01:16 AM
VikingDiesel
Aug 25, 2012 05:56 AM
Ad!
Feb 7, 2012 12:56 PM
