Throttle Position Sensor: screw size?
Old Dec 10, 2017 | 09:31 PM
keoni004's Avatar
Default Throttle Position Sensor: screw size?
Hey everyone. I just went to replace my throttle position sensor and found not only a missing screw, but a stripped hex bolt in place of the torx that the manual says is supposed to be there.
1. What's the PN for the screws?
2. Alternatively, what size are they if I were to replace them?
3. My proposed plan of action is to use an EZ out bit - any danger of using PB Blaster on the sensor housing?
Thanks!
Old Dec 10, 2017 | 10:23 PM
OverRover's Avatar
No damage using PB Blaster, you only need a very little so don't go nuts.
RE: The TPS screw/bolts this is what you need > https://landroverforums.com/forum/di...s-bolts-83593/
Old Dec 15, 2017 | 03:19 PM
whiskeynipple0088's Avatar
i believe it is the very common 5.5 mm torx-- at least thats the head size
LRD2&ME
May 13, 2019 09:25 PM
LRD2&ME
Aug 19, 2011 11:04 PM
LRD2&ME
Jul 8, 2011 07:16 PM
LRD2&ME
Jul 5, 2011 04:30 PM
rykrover
Mar 2, 2010 06:28 AM
