TicK Tick Tick
Old May 5, 2011 | 07:51 AM
Time to get real, quit thinking good gas or better oil will fix it, it won't. At your mileage, it is safe to say you have a serious valve train issue. I would start with doing an oil pressure test to make sure that old pump is still up to the job, then it is really time for a semi-engine overhaul, oil pump, timing chain, cam, lifters, push rod and a new set of rocker shafts and arms, cause they are worn out.
By the way, it won't be sleeves if you are not adding coolant and have none in the crank case.
Old May 5, 2011 | 08:42 AM
DiscoJag's Avatar
It looks like Disco Mike has the answer. With a truck that old and with that many miles, all things considered, that doesn't sound like a big problem.
Old May 5, 2011 | 09:48 PM
Originally Posted by kevlor80
Ok.... which high detergent oil would be recommended....and which weight or blend?
I really appreciate all this info....truck is in exceptional condition and would like to have it running reliable for my son or daughter to travel with.
Shell Rotella 15w-40 with a NAPA oil filter.
Do that before anything else and see what happens, worse case you're out the cost of a oil change.
No need to cut off your arm because you have a hang nail.
Old May 5, 2011 | 11:37 PM
kevlor80's Avatar
I was hoping that 146,000 miles was not a tired engine. I will see if this last oil change with rotella T 15-40 will continue to make a difference and hope that a top end job is not required for a while. Will do a oil pressure test asap( any quick way to do this?). No sign of coolant loss or in oil.
Spike555 I get the point about using Lucas with a detergent oil (defeating the purpose) and that was a very interesting link about the effectiveness of additives of any kind.
Kevin
xengineguy
Nov 12, 2015 12:23 PM
XCELLER8
Sep 19, 2009 03:27 PM
zracin
Mar 7, 2008 01:17 PM
Kraftyz51
Aug 19, 2007 03:58 PM
97XD
Feb 2, 2007 07:46 PM
