Tie Rod ?
Old Feb 11, 2011 | 12:40 PM
joefresso's Avatar
Default Tie Rod ?
My mechanic told me I need tie rod ends replaced for both fronts. He said he called around and can't find the parts, but I found the following for 98 SE....can't tell which ones I actually need though:
http://www.drivewire.com/vehicle/199...y/tie-rod-end/
Any thoughts?
Old Feb 11, 2011 | 02:21 PM
Chris-bob's Avatar
Not sure...do you have a '98 SE?
http://www.roverparts.com/Nxt/search...nts%5CRod+Ends
Try here.
Old Feb 11, 2011 | 02:24 PM
joefresso's Avatar
Yes 98 se
Old Feb 11, 2011 | 02:51 PM
errose2002's Avatar
I got the follow for my 98 Disco
http://www.undergroundrovers.com/TF2...ds-P22325.aspx
I put them on myself and then took to local tire shop to get alignment done. Pretty heavy duty and the steering is quite a bit tighter now too. Only issue I had was one of the rubber boots had a small rip in it. I was able to get it replaced and it works great.
Old Feb 11, 2011 | 03:14 PM
joefresso's Avatar
Just don't want to get the whole rod when all I need are the ends.
Old Feb 11, 2011 | 07:18 PM
antichrist's Avatar
http://www.rovahfarm.com/DiscoISteering.htm
About 3/4 the way down. Trevor has 3 makes to choose from.
He'll ship them USPS flat rate priority mail.
Old Feb 11, 2011 | 07:23 PM
joefresso's Avatar
Looks good. I notice the right side reads " 2 required for track rod and 1 for cross rod assembly" and left side only has 1 required. does that mean I have to buy 3 of the same for the right?
malmberg
Aug 9, 2009 07:57 PM
Christian_X
Oct 27, 2008 05:54 PM
ljdiscovery
Aug 4, 2008 08:57 PM
cbwhitley
May 29, 2007 06:44 PM
jcw
Oct 27, 2006 08:26 PM
