Timing Belt
Old Apr 17, 2016 | 07:26 PM
swagman's Avatar
Default Timing Belt
Hi,
I have a 1993 discovery (old but still goes well), it started making a strange sound, as the fan had a slight wobble I replaced the water pump. Noise was still there so I disconnected all belts and ran the engine and the noise was still there. So I assume the timing belt is the next area to look at as the belt is 9 yr old but only done 40000 kms. Reading other posts and looking at kits available I have some questions for the more experienced.
As money is an issue, what is the bare minimum that has to be replaced.
Do I need to replace cam seals and orings.
Can I use the old idler and just replace the tensioner.
A kit has an injector pump gasket, does the pump have to be removed also.
Also any other advice for doing this job, I will be getting the fuel pump pin and flywheel pin. Also have the rave manual.
Thanks for any input.
swagman
Old Apr 17, 2016 | 08:26 PM
TOM R's Avatar
What engine?
Old Apr 17, 2016 | 10:09 PM
swagman's Avatar
Sorry.
200 TDi.
Old Apr 21, 2016 | 05:55 AM
TOM R's Avatar
With the diesel you may have better luck at say defender source.com , not many diesel discovery in the usa
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
jerrytrancik
Freelander
Dec 12, 2005 06:55 PM
tonygallagher
Oct 4, 2005 12:14 AM
VB_Rover
Jun 8, 2005 11:51 PM
