Timing chain install questions
Old Jan 22, 2018 | 08:04 PM
ROB99DISCOSD's Avatar
Originally Posted by robertf
Well if its a 4.0 or 4.6 it wll only have a woodruff key in the crankshaft, the cam gear had it cast in. Crankshaft keyway is pretty long. Never noticed any deformation on them. I think youll do more harm than good replacing it
Funny you say that. I looked into it more and I think you’re right on. Does anyone add anything to the cover gasket or just dry? I commonly see in rave they add Hylosil to a lot of the gaskets including this one.
This is my first internal surgery so I’m trying to get as prepared as possible. Confident with a side of apprehensive...
Old Jan 22, 2018 | 08:11 PM
Originally Posted by ihscouts
Keys and keyways become soft edged. What you don't want is a key to roll or split. Replacing is always a good thing.
Somehow I missed this. Now I’m torn. Two good suggestions.
Old Jan 23, 2018 | 06:10 PM
ihscouts's Avatar
I repair/replace allot of driven equipment that uses keys; motors, gearboxes, pump impellers, shafts and so on. Most folks wouldn't see as much in a lifetime what I work on in one week and I'm the guy who only gets involved when the shiite has hit the fan. I was speaking of "best practice" in my field. We get one chance at it while it's stripped down, we replace everything we can before it's buttoned back up because the one thing you didn't replace will almost always invariably fail and you'll be visiting the same thing over and sooner than later. It's like having one headlight bulb burn out, do you replace just one or do you replace both? Get the logic? I hate do-overs and I've done my share. I'm not saying these keys fail, not at all, I'm just sending a little hard earned experience your way. Don't worry about it so much, it's two gears and a chain. What could go wrong?
Old Jan 24, 2018 | 05:37 AM
number9's Avatar
"best practice"
Says it all.
You don't want the one in 50k key failure to happen to you.
Old Jan 24, 2018 | 04:39 PM
I agree. I also abhor doing things twice. If I replace a power steering pump I replace all the hoses, the pulley, etc. I do a whole system. Usually more costly but it’s piece of mind.
If I could I’d pull the whole block and rebuild it but it’s my DD and I’m restricted to what I can get done in two or three days, in a carport, in south Florida weather.
Old Jan 26, 2018 | 10:14 PM
Crunkgringo's Avatar
I just did this on my 97 and to be honest all I did was slip the old gears off then line up the new gears on the new chain so that the casting in the cam and the key in the crank lined up when they slipped on. I torqued the cam bolt and I was done. I don't see why you would need to rotate anything once you have the old sprockets and chain off unless you are deep into it for another reason. I've been driving it for 1.5 months now.
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
possibly owner
Aug 19, 2009 01:45 PM
FTB 2000 Disco
May 15, 2007 07:49 AM
mrach21061
Apr 25, 2007 11:54 AM
