Timing Challenge
Old Feb 1, 2019 | 04:50 PM
RoverDad's Avatar
Default Timing Challenge
Timing was jumping so installed new chain and sprocket gears. Improved but still jumps about 1/2 inch when timing lit. No codes. Idles 5 minutes and then a knocking appears and knocking volume increases. Vacuum test returns a steady 8 value. Driving round the block surges, stumbles, & shakes. Compression test returned all but 1 cylinder as strong so fitted new rings to complete bank. Pulled Dizzy and inspected - Spring loaded good and gear teeth good. Anyone been here before?
Old Feb 1, 2019 | 10:29 PM
Crunkgringo's Avatar
okay... what motor?
Old Feb 2, 2019 | 06:13 PM
ihscouts's Avatar
3.9. Your removing the vacuum line when timing right? Whats the idle speed when timing. The weights are for decelerating, vacuum for idle when timing is set, 5* +/- 1*. How did all the cylinders test when you re-ringed the motor, all good and within a few psi of each other?
Joshua Hollahan
Feb 21, 2017 03:35 AM
za105
Apr 6, 2016 02:38 PM
SWAINROVER
Mar 18, 2016 05:26 AM
mowermechanic
Sep 13, 2009 01:24 PM
RED
Apr 30, 2008 11:37 AM
