Tired of this...
Every year around this time, my rover will lose brake pressure. Today I saw it was about an 1/8th", toped it off with some fluid, and still the pedal will go to the floor. It still stops OK, but there is too much travel.
Im thinking a simple bleed will do, but does anyone know the most common leaks in the brake system? I've checked at the top of the system and at all 4 corners, and there are no leaks to be seen.
i had / have a similar issue. my rears weren't grabbing very well at all. flushed the rear lines. first pump was a big sputter of air. second thru 8th pumps were gushes of fluid that looked like rusty ****. running clear now, but not stopping all that much better. i'm wondering where that air cam from, i cant find any leaks.
im not going to lie, it will be a while before i get to changing things up. Ive been searching around for reasonable coilover parts, and plan on building a set specifically for my rover. But i have to get done fabing up my bumper, cage, and deciding if i still want it to be a functional DD.
jigray3
Oct 14, 2010 06:54 PM
kjj0506
Apr 4, 2007 11:36 PM
rinmud
Oct 1, 2005 04:32 PM
