Tired of this...
Old Jun 28, 2011 | 08:37 PM
jbm6287's Avatar
Default Tired of this...
Every year around this time, my rover will lose brake pressure. Today I saw it was about an 1/8th", toped it off with some fluid, and still the pedal will go to the floor. It still stops OK, but there is too much travel.
Im thinking a simple bleed will do, but does anyone know the most common leaks in the brake system? I've checked at the top of the system and at all 4 corners, and there are no leaks to be seen.
Old Jun 28, 2011 | 08:40 PM
If it is heat related I would look into replacing your rubber brake lines.
Old Jun 28, 2011 | 08:49 PM
jbm6287's Avatar
yeah, i might as well do that. The 2" lift isnt hard on the OE lines, but i plan on gaining some mega travel in a couple months, so going to longer lines now wont hurt.
Old Jun 28, 2011 | 08:54 PM
Well my thought is that the rubber is expanding to much because it is old, it gets hot and then gets super soft.
I dont know if thats the problem, I'm just saying...
Old Jun 28, 2011 | 09:29 PM
CUpgt's Avatar
When you pick up that mega travel I may be interested in your TF shocks bc I'm assuming those shocks will be going.
Old Jun 28, 2011 | 10:36 PM
adam123's Avatar
i had / have a similar issue. my rears weren't grabbing very well at all. flushed the rear lines. first pump was a big sputter of air. second thru 8th pumps were gushes of fluid that looked like rusty ****. running clear now, but not stopping all that much better. i'm wondering where that air cam from, i cant find any leaks.
Old Jun 29, 2011 | 01:06 AM
jbm6287's Avatar
im not going to lie, it will be a while before i get to changing things up. Ive been searching around for reasonable coilover parts, and plan on building a set specifically for my rover. But i have to get done fabing up my bumper, cage, and deciding if i still want it to be a functional DD.
jigray3
Oct 14, 2010 06:54 PM
JBeezy53
Apr 17, 2009 08:04 PM
kjj0506
Apr 4, 2007 11:36 PM
bobby82569
Mar 15, 2007 11:28 PM
rinmud
Oct 1, 2005 04:32 PM
