RRC-Swapping tired 90 3.9 for 95 4.2 in-Any Info?
Old Apr 4, 2007 | 11:36 PM
kjj0506's Avatar
Default RRC-Swapping tired 90 3.9 for 95 4.2 in-Any Info?
I will be leaving the anciliary front end stuff ( alt, ps pump , serp belt, a/c ) . I am curious about the Injection and ECU , Exhaust , and any other tricks or info. I have heard that the ECU is mapped differently and I don't know if I should grab the ECU or use the old 3.9 stuff. Is one or the other detrimental or higher performance or ??
Any one used headers on this set up ? Is there a benefit? I thought I might freshen up any hardware and then do a cloth header wrap to cut under hood heat a little ... anyone?
I understand that I will have to remove the manifold anyway to get to hardware on the back side.... Should I throw a cam in there since I am part way to it anyway? Any upgrade cams that don't take away from reliability or mileage ?
If there is anything I am missing or comment or info that may help - your help is greatly appreciated.
Thanks in advance
KJ
BTW - I am not looking for a barn burner - just reliability and if there is a reasonable gain available I will take it as long as the trade off is not too extreme.
jigray3
Oct 14, 2010 06:54 PM
jigray3
Oct 9, 2010 09:27 AM
JBeezy53
Apr 17, 2009 08:04 PM
bobby82569
Mar 15, 2007 11:28 PM
rinmud
Oct 1, 2005 04:32 PM
