Tired of reading about spark plugs :(
Old Sep 2, 2011 | 09:35 PM
thehun's Avatar
NGK v-power plugs in mine..work good
Old Sep 2, 2011 | 09:45 PM
discomedic4's Avatar
Start with the cheap copper champion plugs. If you don't like those step-up to the next level. Keep going until you find what works best for you. Then you can inform the rest of us of the best plug.
Old Sep 3, 2011 | 06:27 AM
antichrist's Avatar
Originally Posted by discomedic4
Then you can inform the rest of us of the best plug for you.
Fixed it for you.
Old Sep 3, 2011 | 10:48 AM
nevada ben's Avatar
This is really a two penny, but in my experience building and dyno testing racing motors, unless the combustion chamber has a specific, unique design, it's not often you see a benefit from a plug tip. Getting the heat range right matters quite a bit though. If it's unmodified, the stock heat range is probably right. The main benefit from platinum/iridium type tips is that they can last longer (100,000 mile claims).
In small block Chevies I saw power from NGK v-grooves, but it would only last a few runs/laps and then it would be no better than a standard NGK. I can't explain that with any reason (heat range was right, no fouling) but that's what I saw. In the long run, I could get just as good results with Autolites. I was doing this around the time the "split-fires" came out. Those were a rip-off scam, but I guess everybody knows that now.
On Honda race motors (15k rpm), I ran NGK Iridium, mostly because I learned not to second guess HRC. I knew they worked on it more than I ever could.
My truck (big block) has run over 10 years, 145k on two sets of Bosch Iridiums. They do last a long time.
On my Land Rover, I would put in NGK or Bosch standards. There's no point to high maintenance interval plugs. You're bound to have some reason to check/replace them anyway.
Old Sep 3, 2011 | 11:15 AM
Banzai Jimmy's Avatar
My stock D1 3.9 14CUX engine enjoys Denso u-groove plugs. The PO had Bosch Platinum+4 in it and I didn't notice any issues with them either.
Old Sep 3, 2011 | 12:42 PM
Originally Posted by antichrist
Fixed it for you.
Lol. That was the sentiment I meant I just got side tracked typing it. Thanks for having my back.
Old Sep 3, 2011 | 04:09 PM
Rover_Hokie's Avatar
NGK G-Power work well in my D2, before and after the new Magnecor 8mm wires.
Old Sep 3, 2011 | 04:25 PM
antichrist's Avatar
Well...now that we've all come to consensus on the best plugs...
Old Sep 3, 2011 | 05:26 PM
Kinda drives the point home, huh?
Old Sep 3, 2011 | 06:08 PM
antichrist's Avatar
LOL Well, at least we know what's good for Honda racing engines.
