Torque Convertor bolts
Take a 6 point socket. see how deep the cut is on the inside where the bolt head goes and picture the thickness of the bolt head and cut the remaining off the end of the socket with a thin cut-off wheel. your left with a short socket that just grabs the bolt head and gives you plenty of clearance with a 3/8 ratchet.
13mm socket. you can get them from the passenger side corner with a swivel. They are loctited in from the factory and can be some trouble to remove. Be carful not to bend the reluctor ring tabs when remoing and installing the bolts. If you bend them bad enough they can rip the crank sensor apart.
If bent just sightly you'll find yourself with recurring misfire faults.
Where are you a tech at warwagon, I probably have met you.
You can pm me if you want or not
Yup...18 yrs at Land Rover Monmouth 20 yrs w/ product w/ same dealer, I was the second factory trained tech at LRM(Schneider+Nelson) 1988, and 30+ yrs in the industry.
You know people I know for sure.. I though don't know how to quit this chaos...
Congratulations finding a real life after Rover!!
me 2
03-18-2013 07:17 AM
