Tourqe converter bolt help
Old Aug 20, 2022 | 10:47 AM
TOM R's Avatar
Default Tourqe converter bolt help
I've been away from the Land rovers for a little while. My son and I decided to go to junkyard and pull a trans for the D1 so we can get it going again and we are laying under this discovery one on bolting the trans and I can't figure out how to get the torque converter bolts out the rest of the way
It took off the inspection cover. I was able to get in there and break them loose spin it break the next one loose spin. It break the next one loose. But how do I get them out all the way the oil pans in the way and I don't see an access hole
Old Aug 20, 2022 | 10:59 AM
TOM R's Avatar
I tried to search but only get back d2 rubber plug for access
Old Aug 20, 2022 | 01:45 PM
TOM R's Avatar
So answer is He's a 13 mm box wrench to get the torque converter bolt hole lined up between the block and the oil pan on the side where the starter is. Use a shallow socket and a while a swivel or universal and extension and that's how you get it out
Old Aug 21, 2022 | 12:23 AM
Icannap1's Avatar
If you remove the oil pan you will have full access.
Old Aug 21, 2022 | 07:39 PM
TOM R's Avatar
not laying under it in the junkyard im not lol
yuri
Nov 8, 2021 07:09 AM
cobbcj7
Oct 3, 2017 08:25 AM
RicketyTick
Jul 22, 2014 03:39 AM
ruffram
Aug 24, 2011 11:57 PM
kraelo
Apr 1, 2008 12:02 AM
